TomOliver
513 Vistas, 4 Respuestas
customize setup sheets
Is there a way to create customized setup sheets in featurecam?
___________________________________________
Inventor Professional
Autocad LT
FeatureCam Ultimate
Fusion 360
bhorstTGM48
en respuesta a: TomOliver
This is my customized setup sheet. Just rename the .txt to .html.
TomOliver
en respuesta a: bhorstTGM48
How do I set this as my template rather than the featurecam standard?
Do I put it in a certain file? I can't find anything under options.
Autocad LT
FeatureCam Ultimate
Fusion 360
bhorstTGM48
Copy it here C:\Program Files\Autodesk\FeatureCAM 2018\addins\SetupSheet, I recommend you make a copy of the original.
abhishek.juvekar
Hi Tom,
You can create your own custom templates, either by using the default templates as a starting point or making one from scratch. An option in the setup sheet dialog allows you to browse for your desired template. Refer  SetupSheetHelp.chm available at following location C:\Program Files\Autodesk\FeatureCAM 2018\addins\SetupSheet about more information about the tags currently available with html and excel template which are useful in creating a custom template. You can keep your custom template at the same location.
Hope this helps.
Thank You.
Abhishek
