1158 Vistas, 6 Respuestas
Old DELCAM licence.
Hello again.
My question is: If it's possible to use old DELCAM (before Autodesk) licence on another pc. I have FCAM 2018 Ultimate but old delcam key left. After put in the usb socket error appears and the trial version opens. Any solutions or is it trash this moment? Thanks.
en respuesta a: Anonymous
Hi @Anonymous,
You can use the old DELCAM key, if you still have the paf-file but you can not receive a file from anyone.
Still have last PAFKey which i used before Ultimate 2018 and it doesnt work. I dont know why.
PafKey in C:\dcam\config\pass still exists. It cant connect with old delcam servers if i tried open it in pafwizard.
Okay.. Then I don't know
I talked with delcam employee and he promised tell me a reason. I put it here.IT's a other product than ultimate 2018 and should works.
Ok: Simple solution. After installing Ultimate 2018 it eneabled not buyed options in FCAM 2016. Solution is to click enable license functions again in options (refreshing).
ChrisDPCnc
You can use the key, BUT only on products release by DELCAM before the AUTODESK take over.
Therefore 2018 products won't work with the key.
I think you can still access the old DELCAM downloads area and get a copy of 2016, this is the last version that will work with your key/paf combination.
Best of luck!!
en respuesta a: ChrisDPCnc
Everything is good now. I have 2016 R3 and after refreshing in options (all eneabled in old licence ) all work.
However - thanks for help :cara_guiñando_un_ojo:
