03-06-2018
08:05 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-06-2018
08:05 AM
Hello @Anonymous,
This Add-in wont let you do what I think you are trying to do. Let's simply create a Side Feature which you will trick a little bit to acheive a break edge from bellow a hole for exemple. Looks the attached video as reference.
The step to follow are:
1-Create a cercle at the bottom of the hole
2-Create a side feature and keep only the finish strategy
3-Adjust depth (fist flank lentgh, 5mm + distance pass the sharp edge of the tools, 1mm)
4-Adjust Side leave allowance to negative 1mm + break edge value needed
5-Enjoy!
Let me know if I understoud well your needs?
Cheers ![]()
Jean-Francois Landry
Application Engineer
