03-06-2018
07:46 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-06-2018
07:46 AM
Hi @jgabelYM8TK,
first time that you open FeatureCAM after a new install or update, run it as administrator. After opening FeatureCAM for the first time, it's not necessary to run it always as administrator. Most of the time, this solution will fix some issues link with the interface issue or add-ins.
If you still have a problem with your shortcuts, you will need to reset all shortcuts. See the video attached, it explain how you can reset the shortcuts in FeatureCAM.
These steps will restore the basis FeatureCAM shortcuts and allow you the possibility to use the predefined shortcuts for the view like CTRL + 1 for ISO1.
Let me know if it resolves your issue.
Marc-André Jean
Applications Engineer
