JanNavratil
644 Vistas, 7 Respuestas
FeatureCAM Macro - deactivation of the spot drill in existing drilling feture
Hi all,
I'm creating small macro, purpose of this macro is to create copy of the drilling's which are moved at the bottom of the stock, where it will drill other holes to the plate under the stock with thread.
Problem is, when we have active spot drill at the original holes - these are copied into new holes which should be without spot drill.
I've tried lot of things but I'm not able to disable spot-drill at existing hole by macro.
Any thoughts? :cara_con_una_leve_sonrisa:
Jan
