- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
FeatureCAM Flex License use issue
Ref Support CaseNo:12297994
The flex license resides on a server & Contains 2 FeatureCAM (and multiple PowerMILL) standard & premium licenses.
Multiple users require access to both licenses.
To achieve this the premium version needs to be installed.
This will create a shortcut that will run the Premium license.
However is the user then decide to run in standard mode both licences are taken.
In order to resolve this issue.
The attached .bat file was created the run the desired regedit (changes registry to use standard or premium license) & fire FeatureCAM.
This allow the user to open the desired level of FeatureCAM
The works but I do not like the users modifying the registry & in some cases user do not have the necessary rights to edit the registry key.
Please can an alternative safer method be investigated.
