- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
We have been having similar issues. I noticed that I could never have the pop up windows stay in the same spot on open a new session of FeatureCam. It seems that on initial opening the windows are way at the bottom of the monitor.
I have (2) 32" monitors
I also have a tremendous amount of flickering within Featurecam. I have extensively been in contact with Featurecam on this. It didnt do it at all in 2017. They said, maybe my drivers are outdated or my monitor cable is loose. ( I am up to date and cable is display port plug and is pushed all the way in) Also, this is a Featurecam issue. There is no issue with Mastercam or Solidworks, or anything else.
So yesterday I decided to add a 3rd monitor.
Computer was on and running but NO software programs were open, including Featurecam. I plugged in and turned on the 3rd monitor. Once I did, 2 windows that I had used in the previous session of Featurecam appeared on the screen. They were a feature window of a feature I had edited. All of the info was there and I could actually edit it, like it was still live. I could move the boxes around the screen. Also the interrogate box was there with the last results of what I had measured. I pressed the X in the upper right and closed them. Also the CodeMeter program showed it was open in the lower taskbar.
That seemed weird to me! Also, there has been times that when I hover over FeatureCam in the windows taskbar, an image is shown of window boxes that are no longer open. It is like when you close window boxes, they remain open.
