01-15-2018
01:54 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-15-2018
01:54 PM
totheprint, the file with the .job extension is the one opened with PartMaker that contains all of your CAM programing. The extension that your NC file has is determined by your post processor in either the "File Start, Mill" or "File Start, Turn" NC File Header/Footer format depending on whether it's a mill or lathe post. Perhaps you are saving the NC file to a different location than normal? When you press the "Generate NC Program" button you will be prompted to specify a location and a name for your NC file, please ensure that the file you're trying to open is the one generated at this location. Hope this helps!
Regards
Jason
