ncpapaul
en respuesta a: abhishek.juvekar
Z level finish will not accept Z increments.  The option it there, the values can be changed but it will not execute increments.  Z level finish does the whole thing in one pass, period.
Also frustrating is the fact that "check surfaces" used to prevent any machining on the picked check surfaces...............now they will be seen by the software and goofy attempts to mill the surfaces no matter what.
No one from Autodesk has yet to explain why "check surfaces" quit working when it used to work under DelCam.
