- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Featurecam 2018 - corrupted UI?!
This keeps happening...
I deleted the temp files
deleted the ini
ran in admin
created new document
made the toolbars
set the settings
saved the settings
save the new file (for some reason)
closed featurecam
reopened featurecam
opening in admin or not, as soon as I start a document in featurecam, this happens
btw...
I forced myself to use the Ribbon for 2 weeks, I ended up losing my custom tabs 2 times.
So... I tried to use the Default tabs....that was a mistake
It is entirely unrealistic to use Cam software efficiently with the 10,000 extra clicks it takes to use those default tabs and menus.
That being said, I need help with this one, single, specific issue.
I have recreated this problem, several times, trying to use the toolbars in Featurecam 2018
the INI file is attached, and so is the new document that I saved after making the toolbars and settings
