380 Vistas, 1 Respuesta
12-14-2017
07:29 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-14-2017
07:29 AM
Supressing Output of Y-axis on turret on CitizenM32III wit Featurecam Partmaker
If you have created a program and generate it, you will see that a Y-axis value is issued when you start working on the main spindle with the turret
($ 2). When sending your tools to your switch point.
If I want to change this in the post processor it comes with error messages and changes things in the post processor that I do not want to have changed.
I Had this problem also if working with the turret ($ 2) on the subspill, but it was solved by deleting the output token for Y-axis
(PROCESS 2 GAT-5.0)
T2000 (C.B.D-6.0 H-90)
G50 U50.0 W0. (LOAD OFFSET)
G97 S1 = 1000 M3 M96
G99 G0 Z-1.0T20
X0.
G1 Z3.0 F0.1
G4 U1.0
G0 Z-1.0
G50 U-50.0 W0. (CANCEL OFFSET)
G97 G0 X180. Y0.0 T0
I would like to suppress the output of Y0.0 could someone please help me in doing so
(PROCESS 2 GAT-5.0)
G99 G0 Z-1.0T20
X0.
G1 Z3.0 F0.1
G4 U1.0
G0 Z-1.0
Greetings Ray
12-14-2017
07:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
12-14-2017
07:35 AM
Info,
load your files into Partmaker then use the blue telephone icon at the top of the page to zip the files.
send them to me and i will set you up with a post mod request.
Send to phil.jennings@autodesk.com
thanks, phil
Philip Jennings
Technical Support Team Leader
