671 Vistas, 9 Respuestas
Creating a tool path from an IGS file
What I am having trouble with is the 45 degree profile on the top surface of the part. I can generate the pocket in the space but am having trouble with the 45 degree on the one side. I can get it through surface feature recognition, but I want to be able to eliminate all the features besides that when it creates it.
rfuentes
en respuesta a: Anonymous
so you want to create that 45 degree side, correct?
Christopher_M
Wayne,
You should use a surface mill feature like "z level".  Just select those 45 degree surfaces and change the stock properties to Use part surface dimensions.
Chris M
Applications Engineer
rfuentes
en respuesta a: Christopher_M
i tried that and it didnt work.
Christopher_M
en respuesta a: rfuentes
Can you elaborate on this, or send some images?
Chris M
I get the same result as @Christopher_M see link.
http://autode.sk/2BbxKlr
Thank you,
Jacob
rfuentes
Hello Jd, i hate to bring a thread from the dead but i had a similiar situation related to this and it didnt work out, i was wondering if you could me help me out. i attached my fm file. so my question is how do i get it to mill to the top sharp corner?also it looks like its not milling outside the profile. thanks
bhorstTGM48
I don't see your file attached?
Hi @rfuentes,
Please share your file and I will take a look:-)
rfuentes
here it is
