- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
So this has been bothering me ever since I "upgraded" to FC 2018.
So I will be working on a program, and I run a 3D simulation then, without hitting eject, open a feature to make a change. I click apply or ok, and get a popup that says "Current toolpath computation aborted". I cant continue until I hit eject on the simulation toolbar. Is there some way to turn this new "feature" off?
In all previous versions of FC it would automatically "eject" for me any time I made a change to a feature. It seems silly to make me stop everything, click ok, then click eject, then click ok again when it seems it could be handled the way it always was before, if simulation is active when someone tries to make a change to a feature, stop the simulation automatically......
If it matters, I don't use the ribbon, because it requires several times the number of mouse clicks to use vs the "old" way that always worked just fine.... Also still waiting for the ability to use print preview when not using the ribbon.....
¡Resuelto! Ir a solución.
