spencer.hardcastle
en respuesta a: Anonymous
Hi @Anonymous,
It becomes a little bit more complicated to delete the toolpath feature because the macro will not know which toolpath feature one to delete, especially if the OK button is pressed more than once. My recommendation would be to have two macro's and two buttons. One to delete the feature and one to create it. This would allow you to pass a variable from one to the other to say whether it had been created.
I've done some checking and it looks like we can't access the tool usage tab with the API language. I will check with development and if this functionality isn't currently available, I will create a new feature request and assign your details.
Thanks and hope this helps.
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
