10-17-2017
10:26 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-17-2017
10:26 AM
Well if you can't get the update we should still be able to help you.
I have spoken to our post dept. and they believe like i do that the best path to resolution is the upgrade to 2018.
If that is off the table please let me know and i will see what we can do for you.
You should be able to make a copy of the post and we can show you where in the post you will need to edit the CSS function.
However that means that you will be working with a static copy of the post and any changes made to that post will be the sole responsibility of your company. It also means that any changes made to the licensed post on our end you will not see as your post is a Non-Distributed copy.
Philip Jennings
Technical Support Team Leader
