420 Vistas, 2 Respuestas
10-16-2017
09:10 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-16-2017
09:10 AM
I have some slots that need to be cut on the face of a part. The slots are 1.5 mm wide and .3 mm deep. I want to run a 1.5 mm end mill down the center of the slot to finish it. I created a curve along the edge of the slot and wanted to run the cutter on the left side of the curve. I can not figure this out. Can someone help me with this? So how do I drive a cutter on the left side of a curve for 2D machining?
¡Resuelto! Ir a solución.
en respuesta a:
09:33 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
10-16-2017
09:33 AM
You should be able to do that with a Side feature. But if you just want to run a centerline path, you could also create a curve on center and use a simple groove.
