578 Vistas, 6 Respuestas
How to set up cutom 90deg threadmilling
So have a odd project and not quite getting how to do it.
I need to thread mill a metric 5 lead 39x10 90degree internal thread. I have tried using the solid/AFR and  from dimensions/thread milling.
Using the solid/AFR it does not recognize the feature  as anything other than a hole. Using dimensions/thread milling when trying to set the tool, a 90deg double angle cutter, it will not let me select anything other than a multi-flute thread mill.
Any help is much appreciated.
Zach
