913 Vistas, 5 Respuestas
Moving UCS after tool paths are done?
Hi
I'm very new to Featurecam.
I have a 4th axis indexing part using 4 setups. I've finished programming everything and about ready to post.
Is there an easy way to move a UCS, leave the tool path where it is and re-calculate the job.
I decided at the end of programming that I'd rather reference everything from the face and centre of the 4th axis. I already use this point for the 4th axis index, it would just be convenient to move the 4 setups that actually contain the machining operations to the same location just indexed round by 90 degrees each setup.
Paul
