- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Geometry point dislplay size
How can I change the geometry point display size? Since I upgraded to 2017 it displays as a really small dot, I can barely see it. Paul
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Just to clarify, Select Wireframe to see the pixel size for points.
Philip Jennings
Technical Support Team Leader
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It has been set as a default to "2" and will not accept any number, not even another "2". I have to cancel to escape. It asks me to enter a number between 0.001 and 10000. But will not accept any value, just repeats that statement. Same thing with the Wireframe value. I'm confused and thanks for your help.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes that is correct. When I click on options viewing "wireframe" is my defaulted window. Sorry I should have pointed that out.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've run into this too. It is asking dimension text size for "mm" i just inserted 20. I had to restart Program for it to take it though
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It was somewhat connected to mm. I had some random miniature value in mm in text size and after I put 4mm in there I can now enter any value in point size and it accepts it. BUT it will not display a dot or point rather. When I started I had points but super fine almost unseen. I may be missing something simple right in front of me but it is frustrating.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Give it a greater value. like 20 or 30 pixels I took a snap shot of my settings. See if that helps.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No change using 20 30 or 40 as a value. And I am also quitting the program completely and restarting also just like someone suggested.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Its a bug I think. We ran into this. Turn off or on (not sure what fixed it) use graphics hardware and restart FeatureCam. It should work then
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @ncpapaul,
To fix this problem follow the steps below ensuring the following setting is checked:
•Click on File to bring you to the backstage file menu
•Click on Options
•Click on and expand Display
•Click the Shaded option to bring up the Shaded options menu
•Make sure the Use graphics hardware box is checked. If unchecked, check it and restart FeatureCAM
•Now the point(s) should be visible.
We have reported this to FeatureCAM development team and they are aware of it.
Hope this helps.
If my post answers your query, please click on 'Accept as Solution' button.
Thank You.
Abhishek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Dakin,
go to options,Viewing options and in the General tab you will see the point option you are looking for.
See attachment please.
Philip Jennings
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Paul ,what kind of video card do you have?
i know that some video cards do not play well with CAD/CAM graphics.
Philip Jennings
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
PNY Quadro K620 VCQK620-PB 2GB 128-bit DDR3 PCI Express 2.0 x16 Plug-in Card Workstation Video Card
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This is what is listed as my video card. I bought it in March this year. Thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
All right, lets try this.
open up the Nvidea control panel.
Select adjust image setting.
pick the third option and set it to performance. Select Apply ( See pdf Nvidea1. )
Next select the Set PhysX Config.
Change from auto-select to the Nvidea card. Select Apply. ( See Nvidea2 )
Philip Jennings
