09-15-2017
12:08 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-15-2017
12:08 PM
What version of PDM are you using? My original post is a little misleading. I can import from the vault no problem. The issue is when I go to save a part file or import additional models, the open/save dialog opens in a vault directory, if I try to navigate to any other directory FC crashes at this point. Can you save your part file to a different directory after importing the model? So I just did some testing. I usually import models by using the import command. I tried dragging the model in then saving it to a vault directory and it worked. The problem has something to do with navigating around the open/save dialog if it opens in a vault directory. Thanks for pointing this out. https://www.screencast.com/t/t755YqSxh3l
