- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Thanks for raising your query through Autodesk Forum!
Are you saying drill/mill in FeatureCAM? If yes, then it is already available. While creating hole feature, it asks for machining type in new feature strategies 'Drill only or Drill/Mill. Select drill/mill and check for the options.
Select the strategies that you want to enable. The options are:
•Drill full diameter
•Rough with Drill, Finish with Bore
•Rough with Drill, Finish with Ream
•Rough with Endmill, Finish with Bore
•Rough with Endmill, Finish with Ream
•Rough with Endmill, Finish with Endmill ◦Finish Bottom
•Rough with Endmill to full diameter — this option lets FeatureCAM rough to the final hole diameter without having a finish pass. ◦Use hole milling canned cycle if available ( ) — For machines that support hole/bore milling, such as Heidenhain Cycle 208, Siemens POCKET4, Fagor G88, and Haas G12/13. The hole milling canned cycle is posted using the hole milling format in XBUILD. If you enter a G code, for example G208, for the Hole Milling cycle in the NC Codes dialog in XBUILD, that code displays in the brackets after this attribute name, for example Use hole milling canned cycle if available (G208).
Hope this helps.
If my post answers your query, please click on 'Accept as solution' button.
Thank You.
Abhishek
