en respuesta a: Anonymous
OK,
So, next problem...related to the first. Lets say I'm using a drill-mill to spot a hole, chamfer an edge, and side-mill around a thru-profile. Naturally, I want all of this to happen under the same block of code (all within the same tool change). I can't use any tool from one feature to machine any of the others, since those tool types are not allowed in other places. I can't side mill with a chamfer tool or spot drill, for example. Not all features lend themselves well to using the built in "chamfer" feature and so I have to use Side Milling a lot to produce edge breaks and chamfers. So, the workaround has been to create tools in each category that mimic the tool I want, then re-number them all to the same tool number. FeatureCAM still outputs them each with their own tool change since it still sees them as different tools. The way I see it, if I want to drill a hole with a face mill I should be able to do it! Has anyone found a workaround for this problem?
