423 Vistas, 2 Respuestas
Help changing Decimal place in setup, opperations then tool list
When I go into setup1 for example. Then I go to a feature, lets call it side1. When I look at my tools available, after the name of the too i see the Dia. under that all my tool dia are one place decimal. I need to change that to a 3 place decimal. Attached is a picture of what i need changed. It is highlighted.
en respuesta a: Anonymous
You just need to resize your column.  Hover on the header between "Dia." and "End."  Click and drag to the right.
Thank you for your help.
