451 Vistas, 2 Respuestas
Main Spindle to Sub Spindle Syncronization
Hi All
I keep getting an alarm EX1040 & EX1016 on our Tsugami BO38T. I looked up the messages and it has something to do with Syncronization of main to sub spindle. It keeps happening right at the end of the program when cut off is about to happen. I'm a mechanical design engineer  new to programming Swiss lathe Machines.  I have attached the codes.
Thank You
T
rfuentes
en respuesta a: Anonymous
you need an M5
phil.jenningsM7ZMZ
Hi Tperez,
could you please use the blue telephone icon at the top of the page in Partmaker and send your files to me.
We can look at the post for you and make any corrections necessary.
my  email is phil.jennings@autodesk.com.
i can set you up with a post mod if that is what is needed.
or you can go through  this PDF and enter a case thru your autodesk.portal.
Philip Jennings
Technical Support Team Leader
