3DS Max 2013 Failed install "Error getting file security"
1187 Views, 3 Replies
01-16-2013 08:38 AM
This is what im getting when trying to install 2013....also getting it when trying to Uninstall 2012
log file
"2013/1/16:08:21:14    Note NOTE-PC    === Setup started on NOTE-PC by Note ===
2013/1/16:08:21:14    Note    NOTE-PC    Launch
2013/1/16:08:21:18    Note    NOTE-PC    === Setup ended ===
2013/1/16:08:21:15    Note    NOTE-PC    === Setup started on NOTE-PC by Note ===
2013/1/16:08:21:15    Note    NOTE-PC    Launch
2013/1/16:08:21:19    Note    NOTE-PC    PageOpen    LaunchDialog
2013/1/16:08:21:47    Note    NOTE-PC    PageOpen    LicenseDialog
2013/1/16:08:21:50    Note    NOTE-PC    PageOpen    ProductInfoDialog
2013/1/16:08:22:44    Note    NOTE-PC    PageOpen    ProductSelectionDialog2
2013/1/16:08:23:25    Note    NOTE-PC    PageOpen    FullProgressDialog
2013/1/16:08:23:25    Note    NOTE-PC    Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/16:08:25:12    Note    NOTE-PC    Install    DirectX® Runtime    Succeeded
2013/1/16:08:25:12    Note    NOTE-PC    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:08:25:36    Note    NOTE-PC    Install    Autodesk Material Library 2013    Succeeded
2013/1/16:08:25:36    Note    NOTE-PC    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:08:26:23    Note    NOTE-PC    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/1/16:08:26:23    Note    NOTE-PC    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:08:27:24    Note    NOTE-PC    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/1/16:08:27:25    Note    NOTE-PC    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\Note\AppData\Local\Temp\_AI8522.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:08:29:31    Note    NOTE-PC    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1603
2013/1/16:08:29:37    Note    NOTE-PC    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/1/16:08:29:45    Note    NOTE-PC    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/1/16:08:30:20    Note    NOTE-PC    Rollback    Autodesk Material Library 2013    Succeeded
2013/1/16:08:30:20    Note    NOTE-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
Im on windows 7 64bit
AUTODESK EXPERT ELITE
1394 Kudos
849 Solutions
Re: 3DS Max 2013 Failed install "Error getting file security"
01-16-2013 10:42 AM in reply to: note
Seems like a permissions issue.  This is usually caused by the following:
1.  You don't have local admin Rights.  Verify this in the Control Panel.
2.  UAC is enabled.  Disabled User Access Control and reboot.  It is all kinds of problematic.
3.  You have some sort of Anti-virus protection software that locks down the Program Files folder, etc.
Once you have eliminated all these, try again.
01-16-2013 03:25 PM in reply to: TravisNave
My account is the only user on this computer and it's set to administrator...also disabled firewall, unplugged cable, and lowered the User Access Control down to nothing, and disabled avast antivirus. Same error occurs...I can't seem to uninstall, repair, or reinstall 3ds max 2012 either.
1394 Kudos
849 Solutions
01-17-2013 08:40 AM in reply to: note
I would check your folder security settings for the ProgramData folder then.  Clearly it is a permissions issue caused by policy, virus, or some other unknown reason.
