Re: Blank Activation Screen
08-29-2012 07:44 PM in reply to: gmijares
I just had the same problem w/ 3ds Max 2013 - paste the code into the same files, but find them in the R5 folder instead of the r1.
good luck
09-06-2012 07:27 PM in reply to: dejanxp
non of them can be open with text. the only options are internet app such as Internet exploror, and google chrome
Community Visitor
1 Post
09-25-2012 03:20 PM in reply to: dhafar.sye
THE FINAL SOLUTION......simply make the computer time before the date that you are in by an example two years and start the program the program will work immediately. 100% working in 3ds max 2012 32 bit for xp. Enjoy !!!
Community Visitor
09-27-2012 05:45 AM in reply to: jarrettmoe
Genius solution Smiley Wink
11-14-2012 11:42 PM in reply to: govy86
govy86 - thank you for the solution!
and for those of us that don't code, the " <!-- saved from url=(0016)http://localhost -->" that you copy and paste
goes just under the very first " <html> " you see, which should be the first line from the top.
11-27-2012 10:35 AM in reply to: govy86
i followed all the steps u maintioned but still m suffering from same prob
12-07-2012 01:58 PM in reply to: shwetankpandey2010
Still no fix for this problem? No but seriously, I tried ALL steps and NOTHING works! It's kinda frustrating!!! How to activate? Why do they use IE in the first place?!?!1?!?!?!/?!/!?!?!??!? Come one autodesk, release a patch regarding this issue!
Ironic is that I actually activated autocad (and received e-mail with activation code) but the problem persists...
01-01-2013 01:25 PM in reply to: sefic91
i tried the pasting "<!-- saved from url=(0016)http://localhost -->" thingy
but i cant save it any ideas????
Community Visitor
1 Kudo
02-10-2013 01:09 PM in reply to: JarretDD
I added the tag to every RT, everywhere  and still only blank screen.  And the process required me to discover how f*'d up Microsoft is too, since I had to change Ownership and Permissions for every single related folder to follow the instructions.  Both Microsoft and Autodesk are more focussed on user-control and piracy than the actual functionality of their products.  Whatever you do, DO NOT GET WINDOWS 7, because none of your software will ever work again.
--Disgusted.
02-10-2013 06:19 PM in reply to: gmijares
Hey guys, i need help from you.
My friend needs help in activating his AutoCad 2012 and when i go and check it out, here's what happen:
When I click on activate button, and check the privacy policy and click "continue", a blank window appears..
here's some photos that would picture out our situation..
please help me guys..
