Autodesk Support
144 Kudos
99 Solutions
Re: Problem whit installation of Autodesk Material Library 2013 - Low Resolution
11-13-2012 03:06 PM in reply to: klausco
Hi there,
Go ahead and try installing the libraries on thier own by running the MSI files directly and see if they will install that way. If you downloaded the installer they should be in the below directories
C:\Autodesk\AutoCAD_2013_English_Win_32-64bit\Content\ADSKMaterials\2013\CM\MaterialLibrary2013.msi
C:\Autodesk\AutoCAD_2013_English_Win_32-64bit\Content\ADSKMaterials\2013\ILB\BaseImageLibrary2013.msi
If you are installing from a disc the folders are basicly the same but you will need to expore into your DVD drive and find them
Once you have run both MSIs and have installed all the libraries try installing AutoCAD again.
Jeffry Asbury
