AUTODESK EXPERT ELITE
1394 Kudos
849 Solutions
Re: 2008 32/64 bit installation
10-30-2012 07:14 AM in reply to: QuentinChapman
I believe Darren is right.  Regardless, licensing will not matter if you are using 32-bit or 64-bit. It is all the same.  You should be able to license the product on 64-bit without issue, assuming you install as 64-bit.
Keep in mind, though, that AutoCAD 2008 is only supported on Windows Vista and XP.  It is not supported on Windows 7/8.
Thanks.
