Sindall
en respuesta a: mdavis22569
Good morning Mr. Davis
Do you think if it possible to find the revit 2025 content families?
Sindall
good morning, could you help me with the revit 2025 content families link?
mdavis22569
Hi @Sindall
Have you seen the following:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Where-to-find-Revi...
Mike Davis
bullcom
Please, Japanese link!
mdavis22569
@bullcom  For which software?
Mike Davis
bullcom
AutoCAD Architecture
AutoCAD Mechanical
AutoCAD Civil3D
AutoCAD Map3D
AutoCAD RasterDesign
Revit
Inventor Pro
mdavis22569
@bullcom are they not in your account portal?
Also some of these don't have it for Japanese or it's part of the software as a whole. Example Revit there is only 1 download and you can pick the language.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-BD09C1B4-5520-475D-BE7E-773642EEBD6C
Mike Davis
AutodeskCommunityUser
en respuesta a: j_weber
Hi, would you have the same links but for the French version please?
he_dawoud
The first two links of 3ds max 2025 are the same.
The second part is missing.
order27A8P
2024?
mdavis22569
Use to be a thread. For some reason it's currently down.
Mike Davis
guenfoud_azk
is it full
mksystemKKYVK
is there also a download link for an offline installation for AutocadLt 2025 in Italian?
pendean
en respuesta a: mksystemKKYVK
Language packs are installed from inside the program, as explained in your software's HELP
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-64F5C41F-DC56-475C-BD89-A2E791882A1B#:~:tex....
vigreux_mickael
it's possible to obtain full links for Autodesk DWG TrueView 2025  French ?
mdavis22569
en respuesta a: vigreux_mickael
This doesn't work @vigreux_mickael  ?
https://www.autodesk.com/products/dwg-trueview/overview
Mike Davis
vigreux_mickael
I needs an offline installer for deployement with Ivanti
