Saeedib
en respuesta a: EricsUsername
I found the solution. This is a malware by Autodesk. in order to handle this make sure to go to your anti-virus and black list the software. In order to remove it go to the install location of the file in Autodesk folder and at the same time open the task manager and look for the process. End the task in task manager and then quickly delete the folder containing that software from your PC.
Alternatively you can launch windows in Safe mode and then navigate to the folder and delete the folder containing that file.
If you are an educator like me, it is your responsibility to move away from Autodesk products. since once your students are done with their school, they no longer can afford to maintain the license and they need to relearn all the same concepts through a different software. If you truly care about setting them for success, move over to opensource alternatives.
