mframpton20
2619 Vistas, 3 Respuestas
Uninstall issues Revit 2022
Trying to beta run deployments and back check my work before launching deployments to the groups. I had revit uninstalled revit 2022 via the add remove since autodesk does not use their old installer (yea! (sarcasm)).
Trying to redploy the deployment back on my machine now says I already have it installed. Very confused here.
Searched over the computer and i can still see revit 2022 on my machine in app data, program data and program files. (Grrreat....!!).
natasha.l
en respuesta a: mframpton20
Hello @mframpton20
I am sorry to hear you are having issues uninstalling Revit completely. I recommend conducting a Clean Uninstall of the previous installation & use the MSfixitTool to complete it to remove the residual files for you.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
mframpton20
We had a full install (With all languages) which failed on removal for 2022. We had to remove all of the registry entries manually as well as try and partially run the uninstaller from cmd. Once we did that we were able to get rid of 2022 and redeploy
Abdifatahfarah753
activation and serial number of Revit 2022
