a.laasW8M6T
in reply to: a.laasW8M6T
Ah I see,
That kind of breaks my entire workflow with a lang vise,
I need to use the manufacturing model if I use anycad so I can make changes to the model(remove/add chamfers/fillets etc) without breaking the link.
Annoyingly this was all working in the past, then the issue of fixture collisions appeared where the fixture from other ops was being detected in simulation.
I suppose ill just have to lose the ANYCAD functionality and go back to the way we used to do it, we don't often really need it but it does come in handy when design makes a change then I can update everything without losing all my toolpaths etc.
Probably for the best as the workflow to use anycad is pretty slow and clunky compared to just direct uploading files to Fusion.
Cheers
