jeff.pek
in reply to: LibertyMachine
Thank you for the thoughtful comments. It's difficult to respond completely to all points, so you may see "piecemeal" responses.
One thing that may be less-than-obvious is the CAM component's support for templates. You can store an operation -- with its parameter values set -- to a file, and then use that to create new operations. To use this:
1) Right-click on an existing operation, choose "Store as Template"
2) (Later) Right-click on a setup, and click "Create from Template", then choose the file you saved in step 1.
Note that this functionality is being updated in the upcoming Fusion update to be simpler (to select saved templates), and to support saving these templates in your Cloud storage area.
Jeff
