04-01-2016
12:36 AM
- Mute
- Permalink
- Report
04-01-2016
12:36 AM
selecting the faces only works for the big pocket not the small one (can only select outline for that) ... also weird. The Bore operation saved me, at least i could finish the part .. but super strange, played around with it more and still can't figure out why the pocket operations don't work.
@HughesTooling wrote:It works OK if you select the faces rather than the edges. I'll have a bit more of a play to see if I can figure out why it doesn't work with an edge.
Mark
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Fusion
