1466 Views, 12 Replies
Warning: Collapses generated below bottom.
I try to generate a swarf toolpath with what I think is a valid selection. But I get the warning: Collapses generated below bottom.
Anyone know what I'm doing wrong? I can't find a thing about this subject.
I added a screenshot for some clarity
Coert
Labels (1)
seth.madore
Could you also share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Hi Seth,
I added the f3d file.
The 'problem' is located in the swarf setup.
in reply to: seth.madore
I ran in on my machine, no problems there
seth.madore
I'm unsure what the warning is trying to tell us. I've run this by the appropriate team, I'll try to circle back when I have an answer
Seth Madore
paulsra
hi guys, is there a solution to this error yet?
I found out that it occurs when using tool offset (in Z)
zach.allaun
Running into this issue as well in a Trace toolpath. Using the Trace for a chamfer. Setting Sideways Compensation to Left seems to cause it, but I have no idea why.
ed
Same problem here for a Trace chamfer.  Runs fine, just anoying having the warning show up with no explanation what it means or how to fix it.
Collin_Korver
Any update on this error?
in reply to: Collin_Korver
Not me! Maybe @seth.madore knows more.
I did mill with this warning tho, with a Swarf toolpath
@seth.madore
Do you know if there is a solution / fix for this? Still getting the warnings!
seth.madore
Could you share a recent file that is showing this error?
Seth Madore
