- Mute
- Permalink
- Report
can't get past 'Warning: No passes to link' with simple pocket
i'm at my wits end ... i had this working and generating without problems .. then i changed the stock reference point and suddenly the pockets won't generate anymore, even when i switch back to the original stock ref point. I need the stock reference point to be on the top since my Z-axis can't reach all the way down to the workbed. But i need to keep the X/Y origin the same.
i have played around with the settings for an hour now trying to get this to work again but i'm really stuck now, no idea where this is coming from.
These are the pockets:
the operations with the problems are:
File is attached. I really don't see what the problem could be especially since it was working before. Tried to reselect the stock, contours .. nothing works. Also played around with the settings on the bigPocket operation but the smallPocket is unchanged from when it was working before.
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Fusion
