02-27-2021
03:05 PM
- Mute
- Permalink
- Report
02-27-2021
03:05 PM
Haas UMC - probing geometry fusion post error
Hi - I did not think this was a machine limitation... But if I have a hole that is offset to the WCS, by B axis and C axis and I try to use tool orientation with my probe to pickup the bore geometry (I want to adjust my tool wear) I get this post error
Error: Your machine does not support the selected probing operation with DWO enabled.
Error at line: 2133
Error in operation: 'Probe Geometry2'
Failed while processing onCycle() for record 365.
02-27-2021
07:34 PM
- Mute
- Permalink
- Report
02-27-2021
07:34 PM
The Haas control does not support probing while using DWO.
To get around this, create a new setup and set a different WCS with the machine in the proper orientation to probe your feature.
For example, machine your part using g54, then set a new datum for g55 on a finished surface of your part and run the the applicable probe cycle.
02-28-2021
10:11 PM
- Mute
- Permalink
- Report
Fusion
