in reply to: Don.Cyr
Disabling polar interpolation in user parameter of Haas post results in XCZ output which drives X axis below X0.
If part feature is larger than available stroke of X axis below center line, you have a problem.
Idea is to force use of Y axis instead by one of the methods described in above posts, when you run out of Y axis stroke, your only other option is polar mode, which tends to leave tool marks on center line because tool stops and waits for C axis to rotate before continuing the cut back in positive direction.
One way to minimize the tool marks in polar mode is by leaving small amount of stock and repeating finish pass, making tool pressure and deflection negligible and less evident.
