Don.Cyr
in reply to: phillip.sheridan
I had inquired about this in the past but didn't follow through as I haven't needed it much recently. Seems the Haas post gives you the option of using polar vs X/Y coordinates and I have used that in a pinch just to generate toolpath code and edited the rest to work.. Maybe someone can integrate that code from the Haas post file into the Doosan post?
Please click "Accept Solution" if I helped with your question or issue.
