02-14-2021
10:39 AM
- Mute
- Permalink
- Report
02-14-2021
10:39 AM
The Doosan post has several machine choices, within the "puma" section I changed the x axis limit from zero to -50mm as suggested in this answer. The specific 90 degree milling head in the machine (Puma 2600SY) will go to -57mm, (as in the spec on the mill head ). The post output then changed to xy, instead of xc. No changes were required in the machining operation parameters. I believe you are correct as far as XC polar, when I need that feature, I will have to go back to the unmodified post. Hopefully I won't have a part that requires both![]()
Thanks for the help![]()
Fusion
