HughesTooling
in reply to: VGBenjamin
A couple of problems. One you have no depth set, you have it set to selected contours and they are at the top of the stock. In the second op you have a closed contour and no room for the cutter, selecting the edges of the body will work better as the CAM then knows which side to machine.
Selecting the edges on this part is pretty tricky @seth.madore  can you take a look? Select a single edge with the Alt key presses then click on the selection to bring up the selection toolbar and select along the rest of the edge. See screencast. File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
