- Mute
- Permalink
- Report
When I am doing a 2D contour operation I have the following error. Do you have an idea how to fix it please?
I have attached my file to this topic
Enabled feature flags: online-system-library setup-sheet-viewer tool-library-v4-release
Invalidated: Generation failed
Debug: This operation depends on operation Bois 1 - Vertical.
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\VANGAN~1\AppData\Local\Temp\Fusion360CAM\2\operation7.ironjob
Debug: Writing jobfile to C:\Users\VANGAN~1\AppData\Local\Temp\Fusion360CAM\2\operation7.hsm-job
Debug: Using CAM kernel from: C:\Users\vangansewinkelb\AppData\Local\Autodesk\webdeploy\production\c1a39fe96c80078ad566b938d0f03989f4b85b09\Applications\CAM360\camkernel.exe
Error: Internal CAM kernel error. Please report through your support channel.
Debug: Autodesk CAM Kernel 3.6.2 (ec5a9f5e) x64 STABLE vs2017 ec5a9f5ee12866256d3d50541834c605abc30943 2021/01/27 12:00
Traceback (most recent call last):
File "operation7.ironjob", line 193, in <module>
job.run()
File "lib\hsmkernel\Operations.py", line 187, in run
File "operation7.ironjob", line 189, in onRun
op1.run()
File "lib\hsmkernel\Contour2DOp.py", line 20, in onRun
File "lib\hsmkernel\GeneralContourOp.py", line 584, in onRun
File "lib\hsmkernel\GeneralContourOp.py", line 981, in doLinking
AttributeError: 'Contour2DOp' object has no attribute 'replacePocketPasses'
Debug: Total processing time: 203 ms
Debug: Total elapsed time: 272 ms
Fusion
