- Mute
- Permalink
- Report
When I am doing a 2D contour operation I have the following error. Do you have an idea how to fix it please?
I have attached my file to this topic
Enabled feature flags: online-system-library setup-sheet-viewer tool-library-v4-release
Invalidated: Generation failed
Debug: This operation depends on operation Bois 1 - Vertical.
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\VANGAN~1\AppData\Local\Temp\Fusion360CAM\2\operation7.ironjob
Debug: Writing jobfile to C:\Users\VANGAN~1\AppData\Local\Temp\Fusion360CAM\2\operation7.hsm-job
Debug: Using CAM kernel from: C:\Users\vangansewinkelb\AppData\Local\Autodesk\webdeploy\production\c1a39fe96c80078ad566b938d0f03989f4b85b09\Applications\CAM360\camkernel.exe
Error: Internal CAM kernel error. Please report through your support channel.
Debug: Autodesk CAM Kernel 3.6.2 (ec5a9f5e) x64 STABLE vs2017 ec5a9f5ee12866256d3d50541834c605abc30943 2021/01/27 12:00
Traceback (most recent call last):
File "operation7.ironjob", line 193, in <module>
job.run()
File "lib\hsmkernel\Operations.py", line 187, in run
File "operation7.ironjob", line 189, in onRun
op1.run()
File "lib\hsmkernel\Contour2DOp.py", line 20, in onRun
File "lib\hsmkernel\GeneralContourOp.py", line 584, in onRun
File "lib\hsmkernel\GeneralContourOp.py", line 981, in doLinking
AttributeError: 'Contour2DOp' object has no attribute 'replacePocketPasses'
Debug: Total processing time: 203 ms
Debug: Total elapsed time: 272 ms
- Mute
- Permalink
- Report
A couple of problems. One you have no depth set, you have it set to selected contours and they are at the top of the stock. In the second op you have a closed contour and no room for the cutter, selecting the edges of the body will work better as the CAM then knows which side to machine.
Selecting the edges on this part is pretty tricky @seth.madore can you take a look? Select a single edge with the Alt key presses then click on the selection to bring up the selection toolbar and select along the rest of the edge. See screencast. File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Thanks a lot for your solutions especially the video it was really helpful I understand how to do it now!
Fusion
