wow, that's much better indeed ... i'm not sure i understand what made the difference here .. you say 'set the adaptive clearing more like a pocket.' how did you do this, is it the 'rest machining' option that makes the difference ?
The odd drill heights of the second drill operation are intentional and a result of my odd clamping technique documented here: https://forums.autodesk.com/t5/post-your-tips-and-tutorials/cam-the-toothpick-skewer-trick-or-the-po...
i knew about the ramping but didn't set it up here since i'm not ready to machine and just wanted to have it in the simulation .. i was concentrating on the adpative operation and would have set up feeds(speeds and ramping when i'm ready to cut.
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
