Just noticed the 2d contour is also plunging into the stock, you can use ramp to stop the plunge. You can actually cut to the full dept with a ramp with these settings, turn off multiple depths on the passes tab.
Mark
Edit you might want to reduce the Ramp Clearance Height to 0.25.
Updated file attached.
Mark Hughes
Owner, Hughes Tooling
