seth.madore
in reply to: BrendenEck
This issue is that the holes are not perfectly inline with the actual part. It's such a small value, it's silly:
The solution in this case is to use Tool Orientation to bring them inline.
We created a ticket some time ago to open up the allowable tolerance deviation. I hope to see this solved at some point in the future.
And no, the holes aren't all off the same amount. These 5 are in-line with the part, when I use "Select Z and X axis" for the alignment at the Setup level:
Seth Madore
