seth.madore
in reply to: BrendenEck
Can you share your file? The message you are seeing (setup-sheet viewer) has nothing to do with the issue you are dealing with.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
I suspect that if you turn on Tool Orientation and select the hole as your Z axis, that will produce a toolpath. There may be some slight misalignment going on
Seth Madore
