- Mute
- Permalink
- Report
Every time i try to create a drilling program i get this message
Enabled feature flags: online-system-library setup-sheet-viewer
i have tried several things to try to get it to work it only happens if i have a model sent over to me from other coworkers and recently happened sense the new update but if i create something from scratch it will work any help would be greatly appreciated
- Mute
- Permalink
- Report
Can you share your file? The message you are seeing (setup-sheet viewer) has nothing to do with the issue you are dealing with.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
I suspect that if you turn on Tool Orientation and select the hole as your Z axis, that will produce a toolpath. There may be some slight misalignment going on
Seth Madore
- Mute
- Permalink
- Report
this is just center drilling the holes and still cant create the tool path
- Mute
- Permalink
- Report
This issue is that the holes are not perfectly inline with the actual part. It's such a small value, it's silly:
The solution in this case is to use Tool Orientation to bring them inline.
We created a ticket some time ago to open up the allowable tolerance deviation. I hope to see this solved at some point in the future.
And no, the holes aren't all off the same amount. These 5 are in-line with the part, when I use "Select Z and X axis" for the alignment at the Setup level:
Seth Madore
- Mute
- Permalink
- Report
seth you are a life saver thank you so much its crazy how that tiny value would mess with drilling but i greatly appreciate all of your help
Fusion
