02-02-2021
12:50 AM
- Mute
- Permalink
- Report
02-02-2021
12:50 AM
"Also have you checked that your tool is properly defined. You have diameter and shaft diameter both set at 6mm. Diameter is the diameter of the very tip of the tool as shown in the tool graphic when you define it. "
Thats it!! Thanks for that. I had it set at 6mm, so it was doing as expected. Once I changed the diameter to 1mm which is whats at the end of the cutter, ran the sim, perfect. Awesome thanks.
Fusion
