Hello all,
I have found solution when this happens.
It works for me, please try if it does work also for you.
When the model turns black I have to change the camera from orthographic to perspective and then back.
When the model is reloaded (regenerated) the problem disappears.
Of course, this is not a solution, but it helps. I believe, that Autodesk team will solve the problem, sooner or later.
best regards
